what tools required
turbocat
Car: 1998 Maxima
What tools are required to replace the front wheel bearings on my 1998 maxima, i have already ordered timken wheel bearings part num 510009 and the inner and outer bearing seals, i would like to do all the work myself, and not take the hub to have the new bearings pressed in, thank you
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
Welcome to NICO!
Unless you have a press, you might be out of luck. Also, you may need to check the hubs to see if the worn out bearings caused any damage. When my bearings went out they wore into the hub 1/8th of an inch and I had to buy new spindles. No since in trying to do it yourself when the problems may be worse than expected.
turbocat
Car: 1998 Maxima
ok, i will check the hubs, for wear or damage, so i will take hubs to get new bearings pressed in, thank you
