not sure if it would be the best idea but i knwo some one used a dremel tool to cut it in the shape of a flat head screw driver and it came out with no problem.DeeZNuTTss wrote:something got stuck or someone tried taking my car and now i cant get the key in the ignition. started to take it apart but couldn't figure out how to take the screws or what ever they are out the bottom of the ignition assembly. 1991 240sx s13 thanks
Use a tap and die set. Drill it out a bit, it makes kinda a 'Allan key' shape (hex key). Thats what i did when I replaced my Ign.DeeZNuTTss wrote:something got stuck or someone tried taking my car and now i cant get the key in the ignition. started to take it apart but couldn't figure out how to take the screws or what ever they are out the bottom of the ignition assembly. 1991 240sx s13 thanks
You took the steering collum out to do a 5 speed swap? lolsainifabulous wrote:i had the same problem my friend fortunately fixed it by using those really small screw drivers that you use to fix glasses with he took it out saved a trip to the lock smith we acutaly had the whole steering collum out at the time(was doing a 5 speed swap was installing the clutch pedal)
