What tool for transmission drain plug
whiplash willy
Car: 93 Coupe 90 SR Hatch
I just finished my auto-manual transmission swap, and need to fill my ka24e transmission with fluid. I can't figure out what the name or size for the tool I need to unscrew the drain and filler plug. Can anyone help? I have searched online and looked in my FSM, surprisingly everyone leaves this info out.
eddiec
Car: 91 S13
try the square end of your 1/2 in drive ratchet. better yet use a half inch breaker bar. or you could get the ultra cool half inch square drive socket from the likes of strap-on or ratco...
vlow1210
A more simple method might be to fill it through the shifter as you will not need to use a pump to put the fluid it. Might be less messy as well. If not, the method through the transmission fill hole works.
navysnail
you still need to drain it though
filling it through the shifter is a good idea though, just unscrew the fill plug and stop when it flows out of it. it is hard to get a bottle of gear oil in there unless you have a fluid pump.
ericherm1
Car: 1997 Pickup XE 2.4L 4x4 Single cab short box
1991 BNR32 Skyline GTR
1991 240sx SE SR20DET + S13 Silvia Front end swap (Sold)
you know a fluid pump is only about 6 bucks at your local parts store.......
for the fill plug use a 17mm open wrench.
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
pipe wrench works......if too tight put a breaker bar on it ............
