Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Thu Jun 12, 2008 9:37 am
If you sand it, use a 2500 grit, then a cutting/rubbing compound, then graduate up through the finer polishes.
When you buy the Skyline badging, it shoulf have the sticky tape already on it.
If you need to add sticky tape, use 3M acrylic adhesive tape. It is about $15. per roll.
You don't need to buy the 3M adhesive primer, do as SBD said, and use alcohol.
