What to replace when swapping?
white240
Here is my scenario my black top s13 only has 30k miles on it. Now i want to get as much work as i can onthe engine while it is out,the engine will arrive in about a week or two and i am not sure when gasgets,seals and what not to repair.Please help me out.i know i searched but since i dont have that many miles im jsut not sure if i should do it all or just a few things. thank you.
corn322
Car: 1993 240sx
I'd replace everything. better safe than sorry.
Auto-X 240
Car: SCCA autocross
take off oil pan and valve cover. Make sure the oil pan is perfectly flat with no dent at all. check pickup tube make sure it isn't bent or loose. While these things are off pour oil through the motor while turning it by hand. This will flush some of the old oil out. change the rear main seal and the timing chain tensioner. This is all stuff to do "just in case". Much easier to do now then after the motor is in, especially the rear seal :)
lessthanjakejohn
Quote »Post by NilsHere is a list of what I think is worth getting for the swap... this is not a *must buy* list for others, but, for me I would definitly get this stuff for a swap.
on top of getting an engine, transmission, harness & ecu.
new clutchnew fuel pumpnew fuel filternew sparkplugsnew ign transistornew heater hosesnew coolant hosesnew beltsnew fluidsnew oil filterintakeintake pipebovbov flangefmicextra fmic pipingegt guageboost guageexhaustdownpipe
[/quote]http://www.nissaninfiniticlub....ber=1
Drakon
Car: S13 hatch-SR+bpu's
This stuff isnt necesary thou, the rest i would say is. but u can use the stock side mount and all that.
bovbov flangefmicextra fmic pipingegt gauge
BuudWeizErr
You don't really need a new ignitor chip. I assume Nils just got one because his didn't come wth one. And you don't need to change the timing chain tensioner. You do that when you change the headgasket and the timing chain.
the_invisible
You don't need new belts if your belts aren't squeaking. Many people are using the belts that come with the engine and have no problem. I guess you can change it, but if you got a 98 blacktop, changing items that are in good condition isn't necessary, IMHO. Same for the clutch.
SET240SX
Car: fast rides
the_invisible i wasn't aware of a 98' s-13 black top. Enlighten me.
the_invisible
s13 was in production until 98. I think between 94 to 98, all the s13 had blacktop. The s13 blacktop is very similar to the s13 redtop, except that the blacktop has slightly different ECU tuning. Though, I may miss some stuff.
