what to replace internally?
sausagelinks98
Car: none
So I'm shooting for 310whp and and I hear that the stock KA24DE can take 350 so what are some things I should replace internally to run safer. Like should I upgrade my head gasket, replace my oil or water pump or add ARP head studs? What, any ideas?I have no clue, thanks.
KATwo40
Car: 1993 240sx KA-T
The spleen. That would be the most important.
Just kidding. Leave it stock, boost it.
Bosrudorfer
Car: S14
Get good fuel delivery and a good fuel program, I would recommend Emanage or tuned ECU then a SAFC-II.
Why not go with 275whp? More than enough and way more realistic
sausagelinks98
Car: none
Well I'm shooting for 12's and I think I should be able to squeeze this out. What do you think, so should just leave it stock? head gaske and all?Here my planned setup btw-
Turbonetics .50 trim T3/T04E turbo (.63)KA24DE turbo manifoldJGS400 WastegateKA24(D)E downpipe and wg pipe setT3 mounting studsJGS KA24E oil feed & return line kitTurbo cementEGR PlugPower Steering Resivore Relocation KitExhaust wrap and clamps for downpipeWalbro 255 LPH Fuel Pump Front Mount IntercoolerCustom intercooler pipingIntercooler with Greddy Type RS BOV MR down pipe ACT clutchTurbo wrapApexi intakeDeastchwerks 555cc injectors Z32 MAFSNismo fuel pressure regulatorNismo FPR adapterEnthalpy ECU tunesafc 2Boost gauge 3" exhaust Apexi AVC-R Boost controller Turbo timer (Maybe)AEM wideband
Modified by sausagelinks98 at 3:58 PM 12/5/2006
Bosrudorfer
Car: S14
sausagelinks98 wrote:Well I'm shooting for 12's and I think I should be able to squeeze this out. What do you think, so should just leave it stock? head gaske and all?Here my planned setup btw-
Turbonetics .50 trim T3/T04E turbo (.48)KA24E turbo manifoldJGS400 WastegateKA24E downpipe and wg pipe setT3 mounting studsJGS KA24E oil feed & return line kitTurbo cementEGR PlugExhaust wrap for downpipeWalbro 255 LPH Fuel Pump Front Mount IntercoolerCustom intercooler pipingIntercooler with Greddy Type RS BOV MR down pipe ACT clutchTurbo wrapApexi intakeDeastchwerks 555cc injectors Z32 MAFSNismo fuel pressure regulatorNismo FPR adapterEnthalpy ECU tunesafc 2Boost gauge 3" exhaust Apexi AVC-R Boost controller Turbo timer (Maybe)AEM wideband
The JGS .48 will run out around 300hp so go with the .63
Its basically the setup I have except I run 370cc injector, SR MAF (52FOO) and currently an SAFC-II.
And add a boost controller. I run Greedy Type S and love it.
Good parts
sausagelinks98
Car: none
Thanks^^^, well i'm gonna recur. the BOV and I hear that a good one.
So leave the motor stock and just add the parts? Should I upgrade anything?
O, and I got a boost controller, the Apexi AVC-R
Bosrudorfer
Car: S14
sausagelinks98 wrote:hu?
I meant the quality of parts is good, none of the SSAC junk.
Yes I would leave the motor stock.
BTW how many miles on the motor?
sausagelinks98
Car: none
almost 130k
its going into a 91 KA24DE....soon to be T, coupe.
KATwo40
You have parts listed for a KA24E, then talk about using a 91 KA24DE.
The SOHC (KA24E) parts won't fit the DOHC (KA24DE).
sausagelinks98
Car: none
Fixed and edited
boznuttz
Car: MS13
Just like the thread before....but an extra 10 to the wheels!!! LOL
sausagelinks98
Car: none
lol, its a good goal and I hear 300 is about what I'll need for 12's.Anyone else?Leave it stock?
KATwo40
Allow me to offer up an example:
I just installed a fully built KA into my car. However, the engine I pulled out had been boosted by a T3/T04E 50 trim (.63 A/R exhaust) @ around 8-10psi for roughly 2 years.
This engine was bone stock and running fine when I pulled it...despite having over 200k miles on it!
sausagelinks98
Car: none
LOL nice, I guess I'll leave it them and just install. I though I should install a head gasket or something but from that I guess not.Thanks guys, if anyone else has anything to add plz do.
nissanfanatic
Car: 1992 Nissan 240sx SE
300whp is a very realistic goal for a stock KA. My theory is... If you can make 300-350whp reliably on a KA, then you will kick some serious *** with a built engine when you go for big power...
