BadQ45t wrote:Agreed, passing was the right move.
Brody, you look like your new around here. I don't appreciate being called a yahoo, I have been here a long time. I don't recommend changing fluids OFTEN but I do recommend using good quality fluids especially in a Q45. I would rather change mine far less often and use the higher quality. BTW, the 1st gens and plenty of 2nd gens were 60k spark plugs, this car has 57 which seems doubtful anyways given a MAF failure.
I have been runing RedLine or Amsoil for 10 years in 97' and zero leakage from valve covers, it is an old myth that sythetic fluids are a cause of this. Saying they are harmful just shows that unfortunately you clueless...although you talk a good fight.
Whokidd...keep looking around and while Brody means well, he's got 77 posts and he isn't 100% correct. The one thing he did say that I agree with is follow the manuals directions when you get the car.
Uh-oh, looks like we've stumbled across "forum seniority guy". In case you didn't know WhoKidd, every forum on the Internet has one of these guys who thinks because they've been around the longest they know the most. They like to regularly remind newer of their join date and running post count as if it's some kind of achievement. In reality of course how long somebody has been a member of a particular forum or the number of posts they've made means jack squat. The only thing it tells you for certain about that person is they have a lot more free time on their hands than most people.
BadQ45t - I would suggest going back and re-reading my posts to Whokidd again. If you choose to do so you will see that...
A. The OEM spark plug on a 1999 Q45 is an NGK Platinum with a 100k mile factory recommended service interval, which can easily be stretched to 120k or more under normal driving conditions. Given the time, expense, difficulty, specialized tools required, and delicate nature of properly torqueing 8 buried plugs in and out of aluminum heads I think anyone who recommends this service be performed at 57k miles is a yahoo. I'm sorry. Wasn't trying to be a jerk, just letting the kid know it wasn't necessary.
B. I never implied YOU recommended changing fluids all the time, just that a lot of yahoos around here do, which is absolutely true. There's plenty of posts around here from Q owners bragging about how they change their oil every 2k or 3k miles. Stupid.
c. I stated that with engines already prone to leaky gaskets like the 99 Q45, synthetics will create more leakage, increase consumption, and generally make the problem worse which is absolutely 100% correct. If you do not believe me, simply zip over to the Mobil-1 and/or Valvoline SynPower website and check out their FAQs on the matter. They fully admit this. But as I put in my post, I have no problem with high-quality synthetics and acknowledge they are far superior to conventional oils in many respects. I just wouldn't put them in an old leaky engine.
D. Amsoil, or as I like to call it, "Amway Oil" is sold through Multi-Level Marketing. For that reason alone I wouldn't put it in my lawnmower and I don't care what the API rating is. Redline is okay. At least it's a real company, not a pyramid scheme, with actual racing heritage behind their products, not network marketers. But the truth is it doesn't matter one iota. You could stick plain old $1.99/quart generic Autozone house brand crap oil in any Q45, change it once every 10k miles, and the damn thing would run just as good and last just as long.
That was my only point...that these are modern, purpose-built, Japanese flagship luxury sedans, not 40-year-old British sports cars. They don't need to be, nor should be, constantly fiddled with. They were intentionally designed and built with the single purpose of lasting a really really long time with very little or no human interaction. If anything, over-maintaining them and constantly d!ck with them is only going to create problems where you wouldn't otherwise have them. That's all I was saying.
