the_invisible wrote:Is there anything to look for? How do I know if the ECU is for the manual s14 engine? How do I check if the harness is uncut and whatnot?
What is there to look for? How do I check for shaft play or see if the turbo is seized?
So generally, what is there to look for? Oil in turbo? These kind of things??
Help would be appreciated! Thanks in advance!
Best advice is take someone who knows what they are looking for with you if at all possible. If not. To check the turbo you'll need to take off the intake elbow and hose. This will expose the compressor wheel. If it's seized you won't be able to spin it. Try to move it up and down. A small ammount of play is OK, by small I mean in the order of .002 - .004" - remember that these turbos have bushings and the shaft is basically suspended on a cushion of oil, so when it's dry there will be some play. Check for obvious visual signs of wear to the blades - running without an air cleaner will screw up the blades easily.
A wiring harness should only be cut on the other side of any plugs that plug into it. If the harness is cut the way many are it will be cut near the back of teh valve cover and will be really obvious - there will be a bunch of 57 wires that have had a hacksaw run through them!
Igniter is about 3" square black thing with a couple of plugs going into it. ECU code I don't know for S14.
Other stuff...
- general appearance will often give you an idea of how godo teh motor is, but don't rely on it.- clutch - no way to tell without splitting the engine trans. No real way to tell you even if they are split.
- PS pump, AC, starter, clutch fan ete. should all be there.If teh cluthc fan is missing, or broken then the motor probably came out o fan accident damaged S14, or had a rough ride across the pond. Check for broken mounts to PS pump and things like that. CAS could also be missing, or broken.s*** there's hundreds of thinsg to check!
If in doubt take pictures and post them.
-Martin.
