Either he bought the engine hoping to fix it, and ran out of money.
Or he got the engine, realized it was screwed up, and is trying to pass his misfortune to someone else.
If you are unfamiliar with motors in general, I would probably try to find a running motor or one from a reputable importer.
That being said, if the motor is together do a compression check and look for consistency.
Pull off the valvecover, look for sludge and any kind of wear on the cams (one of the first signs of oil starvation).
Make sure the turbo is free spinning.
If you are able to, drop the oil pan and look for any debris.
Take some pics and post them up
