What to look for on 91 240SX ECU injector problem
alexh
I have a problem with the car running very rich intermittently -
I have run through all the checks in shop manual and many others.
I'm down to -
Injectors- can an injector get stuck open on it's own?
FPR - haven't checked this.
ECU - Initially I didn't believe that water in the ECU would affect every car the same but a few people have reported on this problem.
After taking the cover off the ECU, what should I look for?
If I'm not able to correct this problem soon I'll have to junk the car so I would appreciate any help.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Sounds like your car got flooded. If so, disconnect every harness connector and use a hair drier to dry out the pins; if the ECU has water in it, do the same thing.
