iamadirtdude wrote:my question to you guys is, I'm looking into some coilovers for under $1k and wheels that i can run low pros and wider tires on. anyway as far as spring rates and dampening what should i look for? and running a stock body s13 whats the widest wheel i'd want to go with? i'd like to use 17's or 18's and what back space?
-f anyone has a specfic coil they like thad be cool right now i was just lookin into some tokico's or basic teins
---a spring rate resonable for street and occasional track use would be 8kg up front and 6 kg in the rearMegen Streets run those spring rates.
-i wouldnt advise going over for daily street driving
---as far as dampening your gonna want to find a coilover that you can adjust the dampening.
---you can run any tire on the rim as long as it fitsfor instance you could run "fat" sidewall or a "thin/small" side wall on the same tire. same goes for width(although with width you cant go wider than what the rim accualy permits you to go)so that means dont run 9 inch wide tires on a 7.5 inch wide wheel..
---Id like to say not to exceed more than 9 inch wide tires on s13s.-by back sace do you mean offset?? 16 or 17 inch wheels fit right at home on s13s
Kapisch?
shrapnail wrote:>< i've been wondering the same to a bit
I've done some reading and it appears to make it easier to initiate that smaller/cheaper wheels are better on the rear (price if nothing else) and then whatever(?) on the front..?
It seems to me that having a more rigid tire side (thus a wider rim) would be ideal for traction.. So putting that on the front makes a certain amount of sense.. Of course having an "odd" set of wheels will look just that... odd
A slight concern of mine though.. if the tires are small enough.. and thus have less rigid sides.. could they not pull away from the wheel in a drift (an engineered blow out??)
I'd really like some good guidance here... i'll prob keep trying to research it.. but some solid input would be awesome.
what your thinking with the "thin" sidewalls is very incorrect
If you run a (wider/fat) sidewall then you increase your chances of the tire accualy slipping off the wheel during drift/hard turning...etc
running smaller rims in the rear will make it easier for your engine to spin them b/c of the sizetheir rotational mass is smaller thus they spin easierbut if you have enough power you dont realy need to run a smaller rim
Hope that clears everything up for you guys
-KC
