What to look for, buying a 01-03 xterra.
240Knightrider
My 240 was ran into. And now the search begins. Ive been searching and researching a lot and believe the Xterra is right for me.
I can afford one about $10k. Which most have about 100K miles. What are some things I should look for that xterra have in common?
Thanks for the help and am looking forward to happy trailing!
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
4wd or 2wd?
There have been TSBs on the power window regulators, so make sure those go up and down smoothly.
If you're looking at 100k mile trucks, be careful if you choose an auto, unless you can validate it's been maintained with regular fluid flushes at 30k mile intervals or t hereabouts. Otherwise, you're likely to have less life left in the trans. 5 speeds don't seem to have the overheating issues that some autos have in hot climates (like Arizona, where I live).
if getting a 4wd, test everything out. Look for leaks. Make sure it shifts in and out well. If equipped with auto hubs like 99% are, make sure you hear them click to disengage when you back up to unlock the hubs after engaging 4wd.
Check steering. The stock steering holds up OK on unlifted trucks with normal offset on the rims, but when you start modifying, the centerlink becomes the weak link. Grab the right front tire and wiggle it, looking for slop in steering components. If it's not lifted, even then, pushing 100k will be time for some R&R.
The timing belt interval is 105k miles. If you don't know it's been done, and you buy a 100k mile truck, figure on doing this ASAP, and replace all belts/hoses, and the water pump while you're at it.
240Knightrider
Cool man, Thanks for the tid bits. Will def use when Im looking!
Oh 4x4 v6
