Asleep Altima »
https://forums.nicoclub.com/asleep-altima-u10022.html
Wed Sep 24, 2003 10:57 am
look for the usual, leaking seals and gaskets, rough idling, wear on the tires as well as the not-so-obvious things... look for wear on the drivers carpet and door sill as well as the drivers seat and the hinges on the drivers door. these are indicators of how much time the old driver spent in the car. check the trans fluid for color and smell. it should be red, not brown or black and shouldnt smell burnt. look at the struts for leakage and the tie rods and ball joints for condition. dont be scared to grab either bumper and give it a good shake too to see how well they are attached. check the core support for rust and corrosion. check the oil and filter to see if its been freshly changed. if the engine is cold and the oil is light, ask to start the engine and let it run for a bit. check the oil again and see if its keeping its color. sometimes people hide bad oil maintanance that way. there are also crumple points in the trunk area you can look at to see if the vehicle was in a wreck. when you drive it, look for play and sloppiness in the steering and suspension.... i know this is alot of things to think about, but its your money, why waste it?
