What to get off of a CA18ET?
AWDB12wagon
Car: 1989 Nissan Sentra 4WD
I found one in a pick'n'pull, what is worth it to get off the car? What size injectors does it run? Turbo? I will be getting a CA18DET this week via freight so I want to start stock piling parts. Thanks guys.~Ryan
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
You might get skinned knuckles and a little less space in your garage.
Not worth it, unless you get the whole car for $100.
boost_boy
Like datto said, stay away from this car as it can't do nothing for you, but cause you unnecessary grief. Sinceyou want to do this AWD thing, target cars such as the AWD axxess as that might be closest thing to an AWD bluebird; or better yet, if you can find an AWD B12 sentra wagon (good luck with that), I'd take the whole thing if I were you. But the 200sx and it's CA18ET engines are not what you want to target unless, you need an extra block or something hard-core like that.
Dee
AWDB12wagon
Thanks for your replys guys, but what about the starter? Some say you can use that one and use the diffrent clutch setup or something?
