Frankenfourty »
https://forums.nicoclub.com/frankenfourty-u139270.html
Wed Oct 21, 2009 11:08 am
[QUOTE=seang]IDK about the DOHC KA's guides. I think they can have problems with the upper chain guide rattling or something like that.
I'm not aware of any life span for the timing chain on either SOHC or DOHC KA24's. It was made to last the life of the engine. The tensioner is very sensitive to contamination and this is likely what causes the excessive rattling on start up.
Early single cam KA's did have chain guide problems because they were backed with plastic. They wear through over time and the situation gets critical. The single cammers found in 96-97 HB pickup trucks have metal backed guides.
When my truck (SOHC 1997 HB 4x4) rattles on start up, I shut it down immediately, and re-start it. This takes care of the problem, and I have been doing this since I bought the truck 25,000 miles ago. I believe the starter to be original, and it is holding up to the repeated use quite nicely. I have been taking measures to clean the inside of my engine, and this has alleviated the issue to 1 re-start, or even zero re-starts. At the worst it required me to re-start it 3, or even 4 times before the tensioner kicked in. That was when I said f*** that, and started using Marvel Mystery Oil in my crankcase a few hundred miles before oil changes, changing the oil more frequently (2100 miles for now), and sometimes changing the filter after 1000 miles. I have manually cleaned the inside of my valve cover using a cleaning brush and gasoline. What came out looked like flat black paint. I rinsed it, and dried it in a 200 degree oven until the breather baffles were clear of water, and re-installed it. This has helped some. I would also like to manually clean the inside of the oil pan, but my truck is a 4x4 and it's a good deal of labor to do that. IDK how that damned engine got so filthy, but I think my dear old Dad may have neglected to change the oil enough during his 6 month tenure of ownership. My intensive treatments have certainly been helping, that's a fact.
About that chain stretch thing, IDK what to make of that unless someone has actually measured an old one against a new one. Like I said, the chain was intended to last the life of the engine and has no factory recommended service interval. Any excessive rattling is likely caused by a sticky tensioner. The plastic guides are what sucked the most.
I did see BigVinnie recommend in an earlier thread that it is still wise to replace the timing set, and lots of people do just that.
Your right, the chain is designed to last the lifetime of the engine. As far as what I said about chain stretching, I wasnt implying that it fails because of this. Its just a fact that they do stretch over time as it wears, but that stretch causes no issues. And I have measured chains in cars compared to new ones and they are a bit bigger than the new ones. Its just that sometimes people misunderstand the difference between chains and belts. So +1 on making that more clear.
