What to do with too much negative camber?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
cfauvel
2005 G35 Sedan and after 2nd wheel alignment in a year or so I see that the camber is not within specs
Spec state that the camber for the front should be between -83 degrees and .67 degrees
My numbers are -1.30 LEFT and -1.21 RIGHT
one option is to replace the top A-arm to a tubular kind which has the adjustments bolts. Not too bad at $187 on ebay.
But was thinking what if I put a certain thickness washer between the a-arm and the body's mounting point, wouldn't that kick out the ball joint a bit and give me less negative camber? But how thick of a washer to get me .43 degrees towards positive?
(Strike the above...won't work....the mounting bolts are parallel to body line)
Thoughts?
Either an aftermarket set of arms or stock replacement upper control arms...
$126 here: https://www.amazon.com/Front-Upper-Cont ... B0779GKKC8
cfauvel
AZhitman wrote:
Fri Dec 04, 2020 9:45 pm
Thanks for the reply...People on other forums think it was the toe-in number that ate the tires
Well, that's not wrong. Incorrect toe plus too much camber will wreck a set of tires in short order.
New arms and an alignment for Christmas!
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
I'm having a very similar issue with my 11 G25X on the front right.
Everything else on all the other corners are all within spec as well as the rest of the alignment specs on the front right.
My front right camber is at -1.8* where it should be as you stated with yours below.
I've been posting in my thread as well if you want a better idea.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
