what to do with bypass valve when you have a bov?
Fenvy
Car: 2005 350Z Base 6MT
I think all stock turbo cars haev a bypass valve, to blow the air back into the pipe and bov blows out.
if I replace the hotpipe and get a bov, what should/will happen to the stock bypass valve?
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
a bov can still be re-circulated into the intake tubing for the most part...either that or if you have it atmospheric, prepare to spend time making it work right
Fenvy
hm.....
what do I do in my set up?
red top sr20det + enjuku custom hotpipe + greddy type s bov
I wouls have 1 working bov and 1 working by pass valve right? do I need to shut the old one some how?
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
no. remove the OEM valve, and replace it with the BOV.
take the time to recirculate the BOV. the factory bypass valve gets removed.
Fenvy
you just replace it at the same spot? I been told that it doesn't work that way, I actually need to weld the stock by pass valve shut and then install the bov on the hot pipe..?
Anand
just cap the stock valve at the point where the vaccume line goes to and you will be fine. no vaccume = valve will not open...
Fenvy
hm... any one got a pic of stock valve for s13 sr20det?
Anand
if you are tlkaing about the side mount then just look at it... it's on the sidemount itself..
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
MainEvent212 wrote:a bov can still be re-circulated into the intake tubing for the most part...either that or if you have it atmospheric, prepare to spend time making it work right
Atmospheric venting=fireballs from the exhaust:D
Anand
[ZERO-S] wrote:Atmospheric venting=fireballs from the exhaust:D
not if you set it right..
I was running Blitz with my stock capped off and at first it was throwing fire but then I messed with it and I didn't back fire at all for the 2 weeks I had it on there.. I even use engine break...
rudee023
Car: '03 Infiniti Q45
I would remove the bypass valve and plug where it use to go on the intercooler. Especially since they have a tendency to leak and takes about 5 minutes to do.
Anand
rudee023 wrote:I would remove the bypass valve and plug where it use to go on the intercooler. Especially since they have a tendency to leak and takes about 5 minutes to do.
what did you use to plug yours? if you did this to yours that is..
GripR
Car: 92 miata
i'm having the same problem what do you do to cap off the part of the intercooler that connects to the stock bypass? weld it shut or i was thinking a round piece of aluminum that will cover it and lots of duct tape?
