pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Fri Jun 04, 2004 11:31 am
The black wire on detonation sensor is a ground, especifically a shielded ground similiar to your RCA wires for sounds system and tv cable at home, it is their to minimize any unwanted and interference signals in the air and generated from the engine.
So yes you need to ground it, and it is usless if you ground it after the sensor, there is a ground shielded wire that goes from the sensor to the ecu, and it is good to have it hooked all the way to the ecu, this way you won't pick up any unwanted noise to falsely trigger the detonation sensor.
PULSAR GTR
