What to do when installing s14 MAF to a s13.
NismoTony
Car: 93 S13 Coupe w/sr20det
Basically what the title says. I got a s14 MAF and installed it into my s13. On the s14 airbox there is a sensor. Should something be wired to that or should I leave it as is. Also when I installed the MAF the car started idling rich. I have removed the AIV system. Is there anything else I should do? Any help will be appreciated.
s13sr20chris
sensor is not necessary if your s13 did not have one.running rich due to diff maf having diff output voltage.
NismoTony
Is there anything to do to make it stop running rich?
574-240sx
Car: Nissans, Toyotas, Subaru
SAFC would be the only thing that could correct while being cost efficant. You will probably have to change the setting for the hotwire.
