SpeedFreak »
https://forums.nicoclub.com/speedfreak-u262.html
Fri Jun 25, 2004 8:14 am
Ok, I have been building my car for 5 years now and I have run out of stuff to do but I still want more........
I was wondering if you guys/girls had any ideas.
here is what I got
SR20detForced Performance Big t-28 turboBored 20 over with Wisco forged pistonsSDS Stand alone fuel/ignition Balenced crank and rodsmsd 10 mm wires with Denso plugs550 Sard injectorscustom made intercooler and pipping3 inch down pipe3 inch test pipe 3 inch catback exhaustPolished Valve coverPolished intake manifold and runnersNismo solid motor mountsNismo thermostatCustom built clutch, one side ceramic, one side kevlarApexi twin chamber BOVSpec 2 pressure plateApexi Avcr boost controllerEquil length turbo manifold256 HKS camsWalbro 255 fuel pumpz32 brakes front and rearstainless steel brake lines all roundFront and Rear suspension techniques sway bars Suspesion techniques flex system Agx 4 way adjustable shocks in front and 8 way in the rear eiback sportline springs front strut barCusco pillow ball mount275/45/17 Kumo mx on 17x9 eagle rims all round Alpine 12 disc changer, amps, eq and deckBoost, egt, air/fuel, oil temp, fuel pres. guages in both a pillersNismo short shifterMomo shifter knobcustom ebrake handleReal carbo fiber dashRacing seat with a 4 point harness for the driver and leather for the passengersapex AVC-r boost controllerSDS stand alone controllerVeilside shogun kitJDM badgingJDM front airdam piece
That is all I can think of but I just wanted to know if anyone had a new piece of equiptment they thought was a solid item to add.
BTW this is not for drag, I mostly autocross with it and drift.
