So i haven't had much progress over past few month , its getting warm and my storage lease is up on 1st of next month...
Basicly
http://members.shaw.ca/uden/kae.avi that clip has audio of my problem...its the loud tapping that comes at about 2500rpm and stays till about 4500rpm . engine is ka24e with about 200k kms new gaskets/clutch not sure about when rings /bearings were replaced , but it bearly burns oil.Noise shoved up out of nowhere about 3 days after new clutch got put in.
I asked few month ago if anyone had similar problem or what should do or try.? most people sad either lifters or oil galleries.
I was donated an extra Head by local memeber.
so i swapeds over lifters/rockers assy made sure there is proper amount of oil in there. still getting the same noise. there is no performance lack but its so damn loud driving it to storage people looked at me like i have turbo diesel truck...
so lifters elimanted ... i used stethioscope and honestly ka is 1 loud motor ,its hard to pin point it, i would say its coming from the 3/4 cyl or bellhousing area. i du not feel that its cousing any vibration on any part of the motor./ i reved the heck outta my car from 2000-6000rpm waiting for noise to go away or for piston to pop out...neither happend.
now i am lost is it:1clutch related ? i used stethioscope and inserted it around the fork area in the transmission nothing special there. 1 thing i can't check is pilot bearing?
2 chain/tensioner ? did my chain skipp a tooth? tensioner defective or oil pump not supliing enough oil?
3 real dirty oil passages in cyl #x and lifter is acting up due to low oil pressure./ can i clean em with wire(plumerrs snake) etc or machine shop is my only option ?
cmon guys help me out here haha i don't wanna pull the motor out and rip it apart to find out that i didn't have too also my space is limited as far as hoisting the motor out can i just pull the head off and than the block, leaving transmission still in the car
ka- me
