C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Tue Jul 06, 2004 12:00 pm
It depends on how bad the threads are. If it's just cross threaded, then you may be able to get away with just running a tap through it. If it's stripped, you can either drill out the hole slightly and then re-tap it for a larger bolt(there may be limitations depending on the thermostat housing) or you can use a thread repair kit. A thread repair kit will also require that you drill the hole out and retap it, but you screw in an insert that allows you to use the same sized bolt as the original. These are a bit hard to find in certain metric sizes, but if you look hard enough, they are out there....
