Yeah I thought of that, but he just said he can't have a CEL or any codes showing. So it depends if they actually want to plug the scanner in or if they're satisfied with no CEL on the dash. Either way you could always try to claim its a 95biggie wrote:More issue with that^ is the OBD2 port has to stay working to connect to inspection machine, using S13 ECU loses that (same for using '95 ECU which is also common).
In Emissions Counties of NC (almost all of them) they look at the registration, see it is '96+ and HAVE to plug it up to the machine. The machine test pass/fail and sends the results electronicly to Raleigh, if failed you can't renew your plate sticker.SX APPEAL wrote:Yeah I thought of that, but he just said he can't have a CEL or any codes showing. So it depends if they actually want to plug the scanner in or if they're satisfied with no CEL on the dash. Either way you could always try to claim its a 95biggie wrote:More issue with that^ is the OBD2 port has to stay working to connect to inspection machine, using S13 ECU loses that (same for using '95 ECU which is also common).
Same for us for <'96, though they test horn and look at tires too.SX APPEAL wrote:Wow that sucks! MO FTW... you got headlights, taillights and turn signals? You're good to go!
man there are strict down here(NC) i seen them pull cars up on the lift to check for the cats.. it really sucks cause theres no way around it..biggie wrote:Same for us for <'96, though they test horn and look at tires too.SX APPEAL wrote:Wow that sucks! MO FTW... you got headlights, taillights and turn signals? You're good to go!
