What tires will fit 18''s?
All things Altima Coupe.
mikethemike
Car: 2010 Altima 2.5s w/ convenience package
I just took the tires off the 18'' Z wheels. I'm not sure which tires to wrap them with
I dont know if it should be 225, 235 or 245. It will have a 45 side wall and obviously be 18.
The wheels are 8 +30 in front and 8.5 +33 in the rear.
I'm hoping either one will work.
Irvxing
Car: 2011 Altima Coupe 2.5s M/T
im using 245/45/18 rear on 18x8+35 lowered in eibachs i rub just slightly on big dips
mikethemike
Irvxing wrote:im using 245/45/18 rear on 18x8+35 lowered in eibachs i rub just slightly on big dips
I take it you rub on the side of the wheels or on top?
SanoSuKe
Probably on top. +35 is not poking out too much, his side wall must be huge though.
Answering your question mike, 245s have much more grip on the road, 235s is a slight stretch if you're looking for clearance and the 225s is a decent stretch if you plan on slamming it.
Irvxing
SanoSuke is right, as always.'
If you have no intentions of dropping the car you can run 245/45 :naughty: no problem
mikethemike
Well, I do want eibachs. Thats all I'm doing. So 235?
el_blacky06
Car: 2007 Nissan Altima Sedan 2.5s 6MT
I ran 245s on my last set of wheels with the eibach springs.
It all depends on what you're going for. If its for function on grippy roads, id strongly suggest 245. If going slammed for looks, id suggest 225s on the front & 245 on the back
mikethemike
el_blacky06 wrote:I ran 245s on my last set of wheels with the eibach springs.
Nah, I wont be slamming it anytime soon. Just Eibachs. So I suppose 235-245 would work then? I like the idea of having a grip on the roads. Taking some turns would probably be the 245 route right?
el_blacky06
yes sir, 245s will grip the road very good. It also depends on the brand of tires. I ran the Hankook evo v12, by far one of the best tires I've used for canyon runs & for daily driving
mikethemike
great! I think I'll do just that =) Thanks fellers
H3llRazr
Car: 08 Altima Coupe 3.5se 6spd mt
F.225/45/18 R. 245/45/18 are a wonder on curvy roads :) I run staggered with toyo proxy plus rear, Hankook evo v12 front and boy do I have some fun
