what tires should i go with ... im lost
tqnguyen72
Car: 240se
sup everyone im new to the 240 stuff i havd a 96 240 i just got some new wheels for the car ... but i dont know what tire size i should go with .. they are 18x8 in the front and 18x9 in the rear .... thanks
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
235/40/18 in the front and 245/40/18 in the rear. This means that your tire sidewall height will be 94mm (3.7in) in the front and 98 (3.8in) in the rear and your treadwidth for the fronts are 9.25in and 9.65 for the rears.
naed240sx
Car: .....
ddgsxr504 wrote:235/40/18 in the front and 245/40/18 in the rear. This means that your tire sidewall height will be 94mm (3.7in) in the front and 98 (3.8in) in the rear and your treadwidth for the fronts are 9.25in and 9.65 for the rears.
245/40/18 is nearly an inch larger in diameter than stock tires.
To the creator:
http://www.1010tires.com/TireSizeCalculator.asp
Use that site^ to closely match overall diameter, or to see other dimensions of the tire.
225 is generally the best fit for an 8" wheel, 235 or 245 for a 9"
Don't stagger your tires very much or it will cause lots of understeer.
This should be enough information to allow you to make your own decision.
BlackFlag_s13
224/40 Front and 235/40 Rear...
