what tire size will sit flush with eibachs?
eslotten
Car: 2008 Dark slate Altima Coupe
My altima coupe is lowered on eibachs and Im getting 18x7.5 wheels very soon. Wanted to know what tire size would i need to get in order for there not to be any gap between my fender and top of tire? Thanks in advance!
downedzephyr
Car: 09 Altima Coupe 3.5se
huge. even with a drop you'll still have a solid 1.5-2" gap
eslotten
ok then what tire size could i get to be closest?
mattyfo0z
Car: 2oo8 CVT - 3.5 SE
I wouldn't say that there would be a huge gap with 18s... I mean, there's not even that big of a gap in this picture and the car still has stock wheels/tires.
With that being said, I'm not sure what size would be best. I'd try to get a 40 or 45 series tire to look best, 50 might be too big and anything smaller than 40 starts to look like a rubber band wrapped around your wheel.
AlexM.
Car: 2010 Nissan Altima Coupe 2.5 Super Black
Dzephyr is very correct.
My advice is to just measure! You can do 18s with a big side wall, or 19s with a smaller side wall and so forth. If you're trying to eliminate wheel gap without running a large side wall, I'd recommend getting coilovers and looking into getting an appropriate tire size.
Here's my fender clearance in the rear:
Once you measure your wheel gap you'll be able to determine what you need to do.
downedzephyr
lol alex showing off his herrafrush stance again... gotta love it!
AlexM.
Just trying to push the movement :gapteeth:
eslotten
With my stock 16"s and eibach drop i only have 1.5" in the rear and 2" in the front for fender gap. So if i get 245/45/18 i should have less than that right?
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
245/45/18 is only .5" taller than stock tires, so you'll close the fender gap by 0.25".
i wouldn't recommend trying to fill your fender gap by just getting bigger tires. if you start trying to get bigger tires than stock, you start to mess with your spedometer and ABS.
IBCoupe
Car: '08 Nissan Altima Coupe 3.5SE
'19 Infiniti QX50 FWD
'17 BMW 330e iPerformance
Jesus, Alex, I'd be afraid to go on the road like that.
Blackmobile wrote:i wouldn't recommend trying to fill your fender gap by just getting bigger tires. if you start trying to get bigger tires than stock, you start to mess with your spedometer and ABS.
beeristasty
Car: 07 Altima 3.5 SE
I think 225/50/18 is your best bet for that width rim.
andyhenault
Car: 2012 Altima Coupe 3.5SR-Borla axel-back, full LED lighting
2010 Altima Coupe 3.5SR-Wrecked
Blackmobile wrote:245/45/18 is only .5" taller than stock tires, so you'll close the fender gap by 0.25".
^This. However, does anyone know of a way to re-program the tire diameter?
funkee
Car: '08 Altima Coupe 3.5 SE
Get one of these bad-boys, and file the tire down until you get it to the right diameter. Grab a 30 pack because it might take a while. Don't go too deep, you still want to keep some rubber on there for the next step. Once you have filed it down to the right diameter, you'll probably be left with little tread left.
So you don't go slip sliding all over the road in your slicks, use one of these to jab at the tire and gouge some holes to give it some grip.
In all seriousness, you can't reprogram it. The speedometer and odometer are analog (someone correct me if I'm wrong). They are based on the number of rotations your tire makes. If you have a smaller tire, you have a smaller circumference. That means you won't go as far in one rotation. That translates to a speedometer and odometer reading that is higher than reality. If you have a larger tire, you'll go farther in one rotation; speedometer and odometer readings will be too low. Usually a difference of the overall diameter of less than 0.3" is okay. There are threads dedicated to it. Check out this calculator: http://www.miata.net/garage/tirecalc.html. The stock tire size is 215/55/17 by the way.
