billy hoang wrote:thanks guys with all the inputs and comments . i'm really feeling it . and taking alot of it into consideration .
hannibal - thanks man ... its very budget ! either i will try to perfect it or repaint it a different color . depending on many things .
KFL - thanks man , i will try to learn and practice in an open lot with cones and hopefully not damage anything but will try to upgrade on brakes since someone mentioned it . safety is always first
chitownguy - thanks for the input , yea Ive been hitting all the other forums to get as much inputs as I can . hopefully i make the right decision .
yokota180sx - i think i might go with the 40 series tires to keep the profile as low as possible to give more clearence . but do you think with that number you gave me with the dimensions of the wheels that I will have to modify the wheel wells , seams and harness ?
azhitman - i will try to research some local forums to see where people is going to get stretched tires mounted . every 6 monthes is not that bad but i will try to squeeze a year . but if its every 6 monthes , i can live with that . i will try to weigh the wheels and compare to stocks and see whats the difference . brakes are expensive but I have learned from past experience that it is very important and hopefully i can get some new ones on the car .
thanks everyone for your inputs and i hope i can get more .
- billy
unless your running 4x4 height yesthis is 17x18 at low as ****in order to run that low i had to bang in all the seams, heat up the front of the fenderwell, bang that in, relocate the harness, bang in the rear of the wheel well, and hop ei didnt rub
then when i put the 18s on iti kept the same height, but i had to go lower to retain the same height, so i found MORE spots that were rubbing/hitting
its a long proces to completely eliminate rubbing at a low height with big wheels, its not for everyone.
