what tire size and offsets for 15x8?
murda-c
Car: 1996 s14
i'm trying to figure out what tire size and offset would be best for 16x8 all around on an s14.
i'm searching and finding conflicting results.
thanks in advance
sorry i meant 16x8
Modified by murda-c at 8:31 AM 4/25/2007
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
a lot of folks will be telling you 0. i for one say to get somewhere in the region of 15-25. it will flush them to the edge of the body without as much risk when lowering it.
murda-c
Car: 1996 s14
http://www.1010tires.com/WheelOffsetCalculator.asp
just found this, makes things alot easier.
whiterps13
Car: white LE hatch
Definately, the calculator probably just answered all of your questions.
Id run a 16x8 +10 with 215/50/16's.
S13NismoStyle
Car: 1993 Nissan 240sx Fb
I also want to run this same size rim, 16x8 with a 10 offset on an s13. I would really lie to run a 225/50/16 and i was wondering if i am going to need a pull to make these fit properly.
Oh yea, the car is on coils and just low enough as to wear the tires are tucking. I have ~2.5-3.0 Degrees of negative camber and also have the fenders rolled.
Will the 225 be too wide or should i go for a smaller tire or will i need a pull to get either tire to fit properly.
sorry to thread jack.
thanks
