What Tire Do You Run on Your 17`s?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Jus14
Car: 97' S14 and 08 Versa
I currently have Fuzion ZR1s because i got all four for 100 brand new,but i really like Yokohama Prada Spec 2`s or maybe like a neo gen and my all weather favorite is Kuhmo...If anyone has any of these tires kinda want to know how the feel and ride on a versa? also the size i run is 215/40/17
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
i have heard nothing but good comments from friends of mine that have yokohama S-drives... they tell me theyre good in wet and dry conditions... as far as the neo gens go, i have a set on my 20's and i like them very much... they seem to be well behaved... but i want look more into NT-05's from nitto...
br4dysays
Car: 06 Nissan Altima SE-R
215/45/17kumho ast's
they seem fine, they came on the rims when i bought them & got about 80% tread left so i'll be using them for a while
BlueMango
Car: 2008 Nissan Versa S Hatchback
215/45/17 - Dunlop Direzza DZ101's
carmo
Car: 92 Accord, 90 Civic, 89 240sx
Hankook 235 40 17
Atx_Versa
Car: 2008 Nissa Versa SL
215/45/17 Barum Bravuris 2
VersaMG08
Car: '10 Mazda 3 s hatchback
'14 Nissan 370z
Are the 205/50/17 Falken ZE329 good to run on 17s?
VersaMG08
'14 Nissan 370z
Also...what about the Falken FK 452? That is another 205/50/17 tire...
williamk10
Car: '07 Nissan Versa SL
thats how i roll
versaspeed.com
Car: Viper GTS & SRT10, Prowler, 300ZX TT, Versa SL 6mt, 240SX Race Car w/track records, Titan LE KC
225/45/17 here and the car is lowered. Offset is +47 (slight brain fade on first post)
Modified by versaspeed.com at 7:11 PM 4/2/2009
reyes1212
Car: '07 Nissan Versa Super Black
I just got some Konig Heliums measured at:+40 offset17x 7.5500kg
so what tire would fit on them?
are the tires with 205 in the beginning low profile tires?My V is lowered on Tanabe Coilovers and with the lip so I don't think I want the low profile ones.
WORKS89
Car: EVO VIII GSR, 07' Versa 6spd, AND 92' Z32
Dunlop Z1 STAR SPECS FTW!!!
http://www.tirerack.com/tires/...ocQty=
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
reyes1212 wrote:I just got some Konig Heliums measured at:+40 offset17x 7.5500kg
I'll answer your second question first:Tire sizes work like this:205-65-15205 is the width of the tread in milimeters.65 is the height of the sidewall as a percentage of the width. So this tire has a sidewall that's 65% of 205mm in height. So a lower MIDDLE number is what you're looking for for low profile. But since that middle number is a percentage of tread width, the sidewall heights of a 205-65 and a 185-65 are not the same. The 185-65 has less sidewall height.And of course 15 is the wheel diameter.
Now onto your wheels. 25mm is 1 inch. With a 7.5 inch wide wheel, I would recommend either a 225 or 245 tire width. 245-45-17 is an excellent tire size that's low-profile and very very common. 225-45-17 is another good option.
reyes1212
I just lodked at my wheel and it is actually 17x7 so would a 205/45/17 be alright
reyes1212
Would my tires rub if I get anything past 235?I'm lowered and with 18's and 225, i'm just a bit paranoid and lost on what tires to get for my 17x 7
reyes1212
Would this tire fit on my 17x7s?http://cgi.ebay.com/ebaymotors...ories
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
205 is really narrow for a 7 inch wide wheel. Usually 205 isn't used on anything wider than 6 inches.
Probably 225-45-17 would be good. That puts you very close to the same rolling diameter as the OEM Versa tires.
Return to “Versa Technical Discussions”
