what thread for oil pressure sensor
dhen
Car: MGA w/ CA18DET
Does anyone know what the thread is for the oil pressure sensor? I'm talking about right above the oil pan on the driver's side. It looks like it's 1/8" pipe fine thread (27). Is this true?
How do I tap it without getting metal in there? I was going to get a q-tip after I tap it and run it for a second so the oil would flush out any metal. Sound OK?
I knocked the sender out and now I can't thread it back in. :mad:
float_6969
DON'T TRY TO TAP IT UNTIL YOU READ THIS!!!!!
It is NOT 1/8" NPT threads. It's 1/8" BSPT. Close, but not quite the same.
http://pipeandhose.com/node/2
If the threads are messed up, I highly doubt you are going to find an 1/8" BSPT tap at the hardware store. You'll probably have to order something off the internet.
http://www.ebay.com/sch/i.html?_trksid= ... &_from=R40
blownhemi
Car: S13 200SX CA18DET HX35
dhen wrote:right above the oil pan on the driver's side.
We get what you mean, because we have this engine, too, but just an FYI, this can get quite confusing in the context of cars and engines which were manufactured in both left and right hand drive versions, even without taking into account the fact that you have it in a completely differents manufacturer's chassis from 30 years before, which was *ALSO* manufactured in both left and right hand drive versions... :)
PS.: for most of us, the oil pressure switch is actually on the "passenger's side". ;)
I wouldn't dare, what you are attempting, with an assembled, running engine I just got up and running fine, but I get that you had your engine apart and not running for quite enough to not want to tear it down all over again.
dhen
Car: MGA w/ CA18DET
:) It;s actually on the passenger side on mine, too. I was tired last night.
Thanks for that, Ryan. I don't suppose I could re-tap it American and then put a plug in it? I have a mechanical pressure gauge.
What is the safe way to do this?
Thanks
boost_boy
Are you sure the thread of the whole is screwed-up or is it that of the sensor. Usually, it is the aluminum threads that take the brunt of the destruction when cross-threading, instead of the steel threads.
dhen
Car: MGA w/ CA18DET
I'll double check tonight. Can I just rethread it to NPT? I've been reading hat his is OK.
If I do have to tap it, how do I avoid getting metal in there?
Thanks
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
Glowshift direct has the 1/8 BSPT male to 1/8 NPT female adapter to use for that port. I have it on my car and use it with my autometer oil pressure sending unit. Works great!
sjbsuperman1425
CA18DET
scratch that, I can't find it on Glowshifts website anymore...I bought two though, and I may still have one laying around. If I find it, i'll PM you if you want and i'll throw it in an envelope and mail it to you.
dhen
Car: MGA w/ CA18DET
Thanks. I found it. Google knows all...
http://www.glowshiftdirect.com/glowshif ... pters.aspx
Thanks again.
sjbsuperman1425
CA18DET
I'll be honest and say I saw that, but didn't see the drop-down menu... :facepalm:
float_6969
LOL!
