What the hell
CaEric
Car: 91 Sr Pwred Coupe
float_6969
I've seen them before. The runners and plenum look awfully rough internally. Cheaper casting. Not a bad price though. I'd like to see before and after dyno comparison's as well as a flow chart for the individual ports.
Bwana
Car: Denali
Very interesting... Looks like a decent quality product.
float_6969
My only concern with them is if all of the runners flow equally. I know the guy that owns CPC out of Australia went through 3/4 designs on the plenum before he was able to get the flows equaled out between all of them. The shape of the plenum and the lengths of the runners are VERY important.
themadscientist
Company firewall sames DAME! can someone host a pic?
davidricardo86
Car: 1992 Nissan 240SX SE
Here you go! Too bad i wouldnt have a way to dyno it anytime soon. I thought about this intake manifold too.
themadscientist
Doesn't look half bad. Anything from thailand is suspect and I would like to see some dyno runs with one in place but it might be ok. What are they asking for it?
tyrannix
Car: go big or go home
themadscientist wrote:Anything from thailand is suspect
+1
this guy knows
-CJ
rotorific
Well if you read on their description supposedly they dyno'd it. They have two in house dynos.
On the other hand JUN Auto was one of the first companies to make a tubular manifold for the 2JZ and it flowed worse than stock. That of course was one of the first setups they made though. -Gabe
themadscientist
that one looks basically like a JUN manifold for the SR.
missionsix43
Car: 1989 240sx hatch ca18det
pretty lame how it keeps the stock lower piece
i dont think its worth more than $300
$500 if it was all sheetaluminum and the full thing, that would be nice.
Swedish Mike
Car: Golf TDI, Volvo 850T5 and 200sx S13 Hatch
missionsix43 wrote:pretty lame how it keeps the stock lower piece
Agree, you normally make it in one piece if you custom make a manifold.The design looks ok but maybe a bit "homemade" in some areas.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
well, if anything it makes replacing the injectors an easier job!
iliketocrash
the injector thing is really a big bonus because with the stock mani it is really a PITA to get those injectors out. However it really doesn't look like they put much thought into the overall design of the manifold because if you look at their other manifolds they make for other cars they look identical... for the most part at least. I would never put one of these on my car. Not because i know a ton about manifolds but rather because i've had a lot of experience with junk off of ebay.
missionsix43
I saw this and thought it was really cool,
http://ka-t.org/intakemanifoldbasic.php
The only thing I would be concerned about is the easiest way to do it would be very short runners (basically only the lower portion would be the runner, unless you put in velocity stacks, which would add maybe 2 inches.)
The other problem is that the ca lower manifold is tapped, for bolts to go into it, so you cannot attach the plenum like in that KA diy.
sideways danny
Car: s13, CA18DET
I think the Ebay item looks good, no point using one until you're going for a lot of power though as you'll lose a lot or response at lower revs
