the motor is a rb20
its an ok deal
, i know the r-32 was owned by http://www.****pit-takatsu.com/
i also know it was an auto and they swapped it into a manual
oil pan gasked / head gasket/ valve cover gasket looks like it was reacently changed as well as the water pump looks much newer than the rest of the motor
it have a built head wuts in it ? no clue yet till i open it up
oh there is another question
there is a blue wire running from the ignitor chip straight to under the dash ?? can it be a push button start ? ignition kill ?
also there is two weird ( look like they are added on not too long ago ) red wires coming out a sensor on the transmission and go straight under the dash to hook on the under dash harness
i will measure the inlet on the turbo soon
thanks guys
