WHAT the hell is
euroboy
i was searching for a while on this forums and on the internet and i am confussed as the dumbest person alive.If someone PLEASE can write a proper, or direct me to a link what eprom or all those c256 thingy are.I know they program the ecu chip but how, what do i need to buy(in the stupidest terms) and how to make it work?
datsunboy
Car: Datsuns
the M27C256 IS the ecu chip ( well it is the EPROM....electronically reprogramable Read only memory )it is the chip that stores all the fuel/ign maps e.t.c..you need to buy the M27C256 ( or a M27C128 is the factory chip...but quite hard to get nowadays....and the 256 one works just the same )then get it "programmed" ( data written to it ). unsolder the factory EPROM chip, solder in a 28 pin IC socket so that you can pull your new EPROM in and out faster for ease of prgramming.
I'd suggest that you get someone else to do this for you if you are having trouble understanding how it works :)
nab911
Car: 93 Nissan 240SX SE
Can someone please email me either a stock or modified ca18det.bin file because when i try to burn my chips, im using a file i got froma a site that is 160k, and it just wont burn. But if i read the chip, then reburn it, it has no problems.
datsunboy
Car: Datsuns
sent you the bin file and a .adr file too
nab911
Thank you! I hope it will work! Im at work right now but when i get home, ill load it up, burn it and pray!
datsunboy
Car: Datsuns
sweet, hope it works for you!let us know how you go
