let me start with a short summary of my first post....yesterday...when my 1991 z32 NA 2+2 was running great:
-- "Blah Blah Blah, never worked on cars before, but I'm going to do it myself...im worried about my jack points and jack stands....i just want to care for my own baby....Blah blah" --
so today, i rolled up my sleeves and said fine, i can do this. had the jack points in my head and the production manual out to make sure i had all my areas covered. My z is reasonably low so i rolled her up on to two wood planks like I've seen done before. had my tire stoppers in the back and went to work.
well yeah, i was on the wrong spot,
http://imgur.com/syKOOZg
http://imgur.com/AmcATRY
the jack was under what i thought was a strong part of the support beam, got it about a foot off the ground on the passenger side, and i heard it start making a noise you know, that slow bending metal noise... i immediately (slowly) lowered the car back down and noticed the four thin lines encased in a plastic bolted next to the beam( running to the back) were not straight anymore. they were before i jacked the car up.
http://imgur.com/QqiRUxE http://imgur.com/pkcgo99
and to my horror, the steering wheel was locked, so i push the car off the planks of wood the break pedal won't move an inch and there is literally ZERO sounds when i turn the ignition.
there are no fluids draining. other then the oil pan leak that i knew about already (could also be a rear main seal)
there is power in the keys first position....
what the hell did i do?
