What the heck is this connector?
I forgot to reconnect it a few weeks ago after replacing the t-stat. Just noticed it today. Didnt seem to affect anything.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
That is the harness connector for the Sub Crank angle sensor, the CAS that comes on if the main CAS fails.....
elwesso
2007 BMW M Coupe
reason why it wouldnt effect anything isbecause the subCAS doesnt work while the regular one is working fine..
Q45tech
The main CAS signal is 360 pulses per rpm [of exhaust cam] 180 per engine revolution.
The SUB CAS is 1 pulse per 90 degrees of cam rotation.
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
Jesda, which page in the FSM directed you to apply the RTV with a spray gun?
elwesso
2007 BMW M Coupe
I think he stuck the tube in the palm of his left hand, and while making a fist with his right hand, firmly but not harshly struck the tube with the lateral side of his fist...
Tech, so the sub cas does indeed remain active all the time, but it is used more as verification for the main CAS?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
911/Q45 wrote:Jesda, which page in the FSM directed you to apply the RTV with a spray gun?
Geez, I thought it was a PlayDoh eruption.
3rd Q
Maxnix,I think he just has a bad case of leaks all over the engine compartment- or he is using the RTV to pre-emptively treat future problem spots- both the fan shroud and the electrical harnesses are known to be very prone to leaking on the '92 Q!.
(Jesda, just kidding man - could'nt resist ! A good DIYer with a shaky RTV tube beats the heck out of a trip to the shop for a simple project!)
elwesso
2007 BMW M Coupe
Note to self,dont let jesda do the valve covers
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
Ahh, thank goodness for plastic covers.
The RTV was splattered about the engine on purpose to distract you from seeing my injector harness wires...
Modified by Jesda at 6:48 AM 4/18/2005
