what the f
mean green s14
Car: driving like a retard
i have a 97 240sx with a ka24de-t and latley the car runs very rought in every gear from about 2500-4000 rpm, if i run the piss out of it it runs fine. just under normal driving at those rpms it kinda hesitates and is jerky. i pulled some codes from it and i dont remember the numbers but one code said "number 1 bank is lean" and there was another for the crank angle sensor and the rest were manufacturer vehicle specific. coukld you please give me a few ideas or point me into the right direction. i will re run these codes and get the numbers for them and post those shortly.
thanks
mean green s14
? someone help me my car is running like sh-t
s13sr20chris
check for vac leaks. spray intake manifold and plenum with carb cleaner while engine is running. if the rpms pick up you found a leak.
