what temps are people seeing ?
beans33
Car: 1993 ca18det 240sx
Hey, what water/coolant temps are you guys seeing with aftermarket gauges? and were did you locate the sender ?
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
my oil temp gauge hasn't seen anything over 215*F..so your water temp shouldn't be higher than that. stock thermostat should be at around 180 or so on the temp gauge. but my friends S14 KA had some thermostat or something goin gon and his gauges (stock and aftermarket) wouldn't go over 100 or so..idk if something was messed up or what but it ran cool!
beans33
so 210* should be ok at normal driving.
sjbsuperman1425
CA18DET
its a little high for me if it stays at that all the time, as it should flucuate between that and 180 or below, since that thermostat would be opening and closing. but as long as it never gets past 210*F you shouldn't be too worried.
rico05
Car: 1992 RMS13 w/ CA18DET
Stock thermostat is 190*. I run a 180*, with electric fans and a stock radiator (used to run a Koyo R1276). I never see more than 190*. I am swapping in a CXRacing radiator in this weekend in hopes of stable temps in Dallas traffic come June.
sjbsuperman1425
CA18DET
i have the Skyline CXRacing Radiator and it never goes over half the stock temp gauge unless it sits and i rev it for a bit without the fan on..when driving i rarely ever have to use the fan to keep it cool.
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
My Autometer oil temp gauge seems to live over 180degF, even on the freeway.I'm thinking I need a better radiator. But my CAs in a small engine bay.
beans33
does anyone know the temp if the stock gauge stays right in the middle.
rico05
That is anywhere from ~180* to ~220*. That thing is basically a 3 way switch.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Dead on 190 degrees with a permacool 14" 2950CFM fan on the stock radiator. It doesn't even try and go up from there, even if I'm sitting in standstill traffic in 100 degree heat. Of course, I have no PS or AC or anything to put a strain on the motor.
I usually run straight water. Blah blah corroding the iron block I don't care.
Buddyworm
My sensor is spliced into the top radiator hose with one of those Autometer things. I tend to sit around 76-78*C during regular driving. Whatever that means for you Imperials :P
Ca_Silvia
Normal summer temps-180-190
Cold weather is obviously less
At the track i let the car cool down once it hits 200
This is all on a completly stock cooling system
dattodude
editing my repost..
It's very interesting to hear the temperatures people are seeing.I'm not sure for mine whether the radiator is blocked, or something in the block is clogged. I'll have to look into it the next chance I get.
Modified by dattodude at 6:04 AM 4/18/2009
sjbsuperman1425
CA18DET
r34 gtr wrote:Dead on 190 degrees with a permacool 14" 2950CFM fan on the stock radiator. It doesn't even try and go up from there, even if I'm sitting in standstill traffic in 100 degree heat. Of course, I have no PS or AC or anything to put a strain on the motor.
only the weak need P/S but i think i may have messed my rack up by having coolant seep into the p/s line fittings.. it squeaks alot now
