SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Sat Feb 12, 2005 4:04 pm
Your years are wrong. There are generally 4 SR20DET's that can be swapped:S13 SR20DET Redtop 1991-1994S13 SR20DET Blacktop 1994-1998S14 SR20DET Blacktop 1994-1998S15 SR20DET Blacktop 1999-2001
The S13 redtop and blacktop are basically the same. There are some differences, but what you need to do in order to do the swap is the same for these when you put them into an S13.
The S14 is harder because the wiring isn't as easy to find, you will need to figure out the wiring for the F3 plug.
The S15 is the most complicated because there are a ton of variables involved like: "Should I use or not use the...S15 speedo, S15 6 speed transmission, S15 rear differential, S15 ECU, etc..?"
