GreenQ45a wrote:Thanks I ment 300zx Adjustable Uppers.
So I can have my current uppers pressed with new bushings?
I saw in other posts people have pressed there tention rods.
Just wasn't sure about the uppers.
I will check out the strut bushings.
She was on flat accumulators for 10,000 miles.(3000 were mine)
Thanks for the help.
The OEM upper links do not have pressed-in bushings. You would have to burn/cut them out and replace with aftermarket. Are you only working on the fronts? Rears have a lot going on as well. Link bushings are not replaceable per OEM design--buy new links. Same for lower arm ball joint. Knuckle bushings and ball joints are replaceable. But I'm only familiar with non-active suspension, so there could be differences.
