27RB240 »
https://forums.nicoclub.com/27rb240-u34021.html
Tue Jan 17, 2006 4:40 pm
I am guessing for 250hp to 275hp if you havent read that page he gave you already, ofcourse you will need a new and larger turbo, FMIC, larger injectors, tuning, maybe a Koyo raidator if you are running the stock one, electric fans (from what I heard dual 10s and 12s are good) nismo thermostat (to keep the motor cool) maybe a Nismo FPR, clutch, maybe a light flywheel, and ofcourse a whole lotta boost...........maybe around 18-20-22....somewhere in that range.......but with larger cams and gears and valvesprings you should be able to get there with alittle less boost.......you are going to need gauges also to make sure everything is running right, pressure, temp,ect..... I think those are the basic upgrades to get you there........And exaust and air intake ofcourse if you dont have it(a 3 inch downpipe and 3 inch exaust would be good)
