What sr20det mod yeilds the most power gain?
turboex
OK im looking to go the route with the best bang for the buck. This is motor stuff guys not suspension and all that.Ok downpipe, clutch, and exhaust are all givens for a new swap. But what other mods add the most powerlike cams? greddy intake? things like this. if anyone has any info on what kinda power these add on a normall stock sr20det with just the downpipe and exhaust i would love to here it. thanks
lucky
Car: chicks, cars, computers
turbo upgrade :)
Daunttless
FMIC because then you can run around 11-12psi without causing the SMIC to explode.
1bad180sx
See that turbo? It made a HUGE difference.
No, seriously though, straight exhaust, no cat, no backpressure, front mount intercooler and good piping. Make it breathe, the motor will thank you for it.
Put in a Walbro/BBK 255lph fuel pump. It's cheap and works much better than the famed GTR pumps, etc.. And it doesn't make that annoying whining noise. You NEED a good fuel pump. It's not a want, its a need.
turboex
What size turbo is that? ands what manifold. I have the pump in already. Also what else did you add to run that turbo? want what you putting down for power and tq? Oh thats a sweet looking setup man!
