rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Tue Sep 21, 2004 5:46 am
You are right.I have an SR intake duct, but becuase it was cut to fit the CA, it only has 1 vacuum port on it (5/8 I beleive) I have the vaccuum for my catch can routed there, but my BOV is vented (I planned on this anyway). I have an SR T25G bolted to the stock manifold. I also had the Stock CA O2 housing (turbo extesnion, A pipe) and CA stock downpipe bolted to it. It did come with SR turbo outleft flange but other than that, it seemed like a bolt in affair (my motorset came with the T25G already on it) As far as cat bcak, all S13 ones are the same.
Note: In my search for an exhaust, I found that many manufacturers make exhausts in both CA and SR applications. Get the SR. Larger plumbing. Hi Power from HKS has 85mm piping, and I love it.
Intercooler will work, but the cold pipe will be a lot of fun (sarcasm) to fit on. I originally bought a SR coldpipe, tried to hook it up, then sold it for a complete CA SMIC setup.Little things like the MAF can be used (if rewired, easy to do tho) and the motormounts (with coersion) can be made to work, although not OE fit.O, and BTW, I have a CA dpwnpipe, and very soon to have a CA stock SMIC setup for sale
