What springs
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
phil4watching
Car: 06 infiniti g35 coupe
What does everybody think that the best springs for a 06 g35 w/ 20" wheels
johnparkyourcar
Car: 03 DG coupe 5AT
Depends on how long you wanna go. I went with H&R sport springs and love em. It was about 1.5 inch drop. Also, depending on your offsets you may or may on run into rubbing issues
phil4watching
I just want a really flush look.... I'm thinking the Tein s-techs.... would that be too much do you think?
johnparkyourcar
I don't think you'd have a problem with those. you should be fine.
phil4watching
Okay cool thank you so much...
johnparkyourcar
If you want flush, I don't think the s-techs would be low enough... but post pics or ban!
phil4watching
I bought H-techs... I'm hoping its going to be flush... I will post pics.. wheels should be here monday
johnparkyourcar
S-Techs are supposed to be lower than H-tech so you should have no problems with rubbing. But H-techs rear springs are known to be a little high. After you install it and if you want to go lower, you could do the spring mount "mod"
johnparkyourcar
A quick search and here's some pics
before
after
Heres some pics of my car. You can see the drop from H&R springs. http://forums.g35club.org/zerothread?id=449404
Modified by johnparkyourcar at 10:53 PM 1/14/2010
phil4watching
what about camber issues with the h tech springs? will i need a rear AND front kit? I was thinking about just going with the rear kit for even wear since the rears wear faster anyway but im wondering how fast the whole set would wear without...
johnparkyourcar
With H techs I don't think you would have to get a camber kit. I don't think the drop would be enough to give you camber. I would like to give you an answer about how fast the wear is without the camber kit but I haven't had one set of rims/tires long enough. After my drop, I switched to OEM 17s, then OEM 19s, and then my HREs which I have on now. Without camber kit, I'm running -3 for rear and -2.5 for front.
phil4watching
Got it all installed... I only have one picture because it's been raining... I'll post more later... I went ahead and got the Tein h-techs and got kinetix rear camber.
[IMG][/IMG]
johnparkyourcar
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
