WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Thu Oct 06, 2005 12:59 pm
Yeah, pretty much what Brian said. The key to picking a spring is to get one that is as close as possible to the amount of boost you want to run everyday. Then use the BC for everything else. I say this because if you want to eventually run 28psi of boost but only install a 5 psi spring, you'll have a leak at high pressure and difficulty reaching a high amount of boost, or alot more lag then usual.
But make sure the motor is ready for whatever boost you're going to throw at it. Welcome to NICO!!
WD
