Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Jan 27, 2005 5:44 am
the machine shop that's charging you that much to resurface your flywheel is ripping you off. I could see $50 at the most depending on how much they have to take off. I just had my flywheel machined a few weeks ago, and at a minor discount my friend gets at the shop, it cost me $25.
The reason you want a resurfaced flywheel is to provide a nice new clean and flat mating surface for you new clutch plate. If you put a new clutch plate on an old flywheel, it has all the material that's been worn into the surface of the flywheel to contend with.
All you need is the alignment tool. As long as you know how to removed the trans, you should be ok. You will want a friend to help you out while you do this. That way one of you can stabilize the trans as it comes off and goes on, and the other can operate the jack to get it back in the car.
The big trick i can give you is to take a 1 1/16th socket and breaker bar, and find a place to brace the crank pully with it while you tighten the bolts on the pressure plate.
