what spark plugs to run?
C - ROD
Car: SR20DET pignose hatch
i am a little confused on what plugs i should run in my motor when i get it all running again, it has 9:1 compression & will be running at 17-22 psi of boost, timing set at like +17-18 degrees running 93 octane gasso any reccomendations on spark plugs would be nicethank u
ILikeMy240sx
Car: SR Power
BKR7EIX is what I run on mine gapped to .028"
C - ROD
ILikeMy240sx wrote:BKR7EIX is what I run on mine gapped to .028"
so what is that like heat range 7?
ILikeMy240sx
Car: SR Power
yup Iridium w/ 7 heat range.
C - ROD
well what turbo u Run? & how much boost do u put to the cylinders, i was thinkn of going with a heat range 8
