Jostudly wrote:Is it possible they pulled a fuse to turn the light off?
There is no fuse you can pull. The TPMS system is integrated into the Body Computer.... this controls many of the functions in the Rogue including keyless entry, vehicle immobilizer, most of the control switches, HVAC controls, etc.
Your best option is to do what I have done for the past 3 winters:
- Cut a 3/8" square of black electrical tape and cover the TPMS warning light. You will not even see it once installed.
- Next spring, re-install your summer tires then remove the tape. The light should disappear within 20 minutes of driving. There are no codes to clear, etc
A few more things:
- The TPMS sensors are not designed to be continually un-installed/installed. They will be damaged in short order this way.
- Not using TPMS sensors
will not damage your vehicle or cause any other issues with the VDC, ABS, or AWD systems.
- Using 2 sets of TPMS sensors would require costly reprogramming of the Body Computer every time you change tires. Only the dealer has the tools needed to program the TPMS sensors.
