What snow tire and rim will fit 2007 M35 sport?
bobbyray51
Car: infinity m35
I'v been unable to find snow tires and steel rims for my 2007 M35. I need a snow tire for wisconsin winter. But no rims are listed for this car. I'd like to have a 17 inch (vs. the 19 stock) and a narrower tire than the stock 245. The tire size is one problem but the wheel offset is another. Any ideas?
daveM45
Car: 2007 M45
Both tirerack.com and discount tire have packages. A few local places I called offered what was a resale from tirerack. No one had steel rims (or takeoffs) but there are cheap alloys for a bit less than $100 each. I went with the MSWT14. Nothing special but not a mark on them after on winter.
I've ordered two winter packages from tirerack and received excellent service both times.
If you search the forum you'll find a discussion we had on the different tires. I stayed with the 18" but recommend the 17" with a softer tire if you're looking for help in severe weather. You'll also want to browse the threads on the TPMS resets. I was bit confused on how to order the package mounted and balanced w/o a TPMS (legal disclaimers and so on) but the friendly sales staff helped out.
infiniti_m45
Car: 2006 Infinti M45 Sport
I have M45 sport on 19"I am also looking for snow tires and while I checked different places they all recommend different rim & tire sizes.
Discount Tire: 225/55 - 17Just Tires: 245/45 - 18 - they stated that 17 won't fit and would be too sensative for transmission, but this size seems too wide for snow.TireRack: 235/50 -17 or 245/45 - 18 Local company: 235/50 - 18 - they recomended not to go down more than 1 rim size so I can only go from 19 to 18 only and not 17.
Now I am totally confused which one to get?
szh
Car: 2018 Tesla Model 3.
Guys, remember to be careful about the offset needed for the wheels on a 2006+ M. It is higher than normal.
Personally, I would recommend getting a cheap set of 18x8.5 wheels (with a 47mm offset), and use 245/45-18 snow tires for winter.
Having driven in New Hampshire for many years, I would be totally comfortable doing the above.
Z
reggiefloyd
Car: BMW M5, used to have M35x
I recently turned in (lease) a 2006 M35x, only had 30,000 on it. I still have the winter wheels and tires that I used -- I bought them from Tire Rack in Dec 2005.
Edit by Moderator: Forsale item information removed from this post.
Please put your sales stuff in the Classifieds section (after following posting rules mentioned in the FAQ there). You may put a link to that thread in your SIG to get attention!
daveM45
Car: 2007 M45
My MSW T14's are 18x8 45mm and came with a small spacer. Tire size is the factory recommended 245-45 18. I've heard a few grumbling about spacers but I have not noticed any problems in clearance, tire wear or ride/handling.
What problems does an incorrect offset cause?Thanks
RM450GT
Car: 06 M45
reggiefloyd wrote:I recently turned in (lease) a 2006 M35x, only had 30,000 on it. I still have the winter wheels and tires that I used -- I bought them from Tire Rack in Dec 2005.
wish you were closer... I would have bought them.
szh
daveM45 wrote:My MSW T14's are 18x8 45mm and came with a small spacer.
Hmmm ... with 18x8 45mm offset wheels, on a 2007 M (that is what you have, right?), you should not have had to use a spacer - it would only be needed for the 2003/2004 M45 with that offset value. The stock wheels for the 2006+ M have 47mm and 50mm offsets - info is in the stickies in this forum.
daveM45 wrote: I've heard a few grumbling about spacers but I have not noticed any problems in clearance, tire wear or ride/handling.
Spacers add rotating weight, alignment problems, potential for unbalancing, etc. Best to get correct offset wheels instead.
daveM45 wrote:What problems does an incorrect offset cause?
With incorrect offsets (using positive offsets as is typical for Nissan and Infiniti vehicles):
1. If the wheel sits too far out (too low an offset value), the tire could come under the fender and could touch the body on bumps (fwiw, I am not a fan of the stretch look!).
2. If the wheel sits too far in (too high an offset value), it could contact suspension components, particularly when turning - on the front wheels.
Z
infiniti_m45
Do you know if 45mm is going to be ok on M45 Sport or I should sill only stick with 47mm?
Modified by infiniti_m45 at 11:41 AM 10/8/2008
szh
infiniti_m45 wrote:Do you know if 45mm is going to be ok on M45 Sport or I should sill only stick with 47mm?
45mm should be okay ... that is small enough not to matter. Particularly if the tire width is not too extreme.
Z
