what size wheels max can i use?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
raw911
new G35X owner and looking at some tires .. cant seem to get an sure answer on the size wheels i can put on car. ive heard only go 18 then some say i can get away using 20's .... also there is the matter of the sensor in the tire to let u know tire pressure ... do i need to use the ones that are on the car tires already or buy new one or just have that feature disabled ... since i am new to all this i need some help ... and when/if i do get my wheels and tires do i go to a Infiniti dealer to have installed?
thanks
raw911
well what size tires are everyone using?
zozoka1212
Car: 08 Infiniti G35x
It comes with 17. Most of us still riding on the original. I've seen 18,19,20 on X. I would like to go 18" but that's just probably next spring. Or might stay with 17. I know it would look better on 18-19 but you need clearance for snowy days. I used to have a neighbur His car had not much clearance. He had a really screwed up winter time. I deceided it won't happen to me. That's why I would not go bigger than 18" If the snow not a factor for you or you looking for some summer tires than go for the 18-19. They look nicer. 20 would be too big I think. I rather lower it than go with 20".
Zozoka
zozoka1212
Sorry forgot about the sensors. They are pricey I would use them it is a good feature in the car. You don't have to worry about the tire pressure. I am pretty sure they are transferable to the other wheels.
Zozoka
5_inch_lip
Car: 2006 G35 Coupe
zozoka1212 wrote:Sorry forgot about the sensors. They are pricey I would use them it is a good feature in the car. You don't have to worry about the tire pressure. I am pretty sure they are transferable to the other wheels.
Zozoka
Yes you can transfer the tire pressure sensor very easily. It takes a few mintues.
Cali 2 Balti G
Car: Desert Platinum G35 Coupe
Dodge Ram Quad Cab
Toyota Sequoia
There is a member named Spacy9 that has a G35X with 20s. He justed posted a thread about his new license plate - so he could be at least one source from someone who has actually done it.
5_inch_lip
Car: 2006 G35 Coupe
Cali 2 Balti G wrote:There is a member named Spacy9 that has a G35X with 20s. He justed posted a thread about his new license plate - so he could be at least one source from someone who has actually done it.
What you trying to say dude. I have 22" on my G35.
zerothread/266644
Gimli G35
Car: 1996 Lexus ES300
hmm will 22's fit on a X ... but yea i thought those sensors were transferrable
Just go to the tire store\rim store .. ask them if you can see a 22" or 20" rim on your front and rear ... then you can estimate what tires you want to run .. Low Pro ? or mids .. warning 22's LOW , 20's .. i have no clue maybe Mids on a X
If im wrong just point me out . i only have 19inch motegi Track Touge
Cali 2 Balti G
Dodge Ram Quad Cab
Toyota Sequoia
I think the 22" comment was supposed to be a joke
Back to the topic at hand - there is another current thread titled G35X suspension limitiations - there are several examples of members who not only have 20s - but they have lowered the car as well.
5_inch_lip
Car: 2006 G35 Coupe
Cali 2 Balti G wrote:I think the 22" comment was supposed to be a joke
The 22" comment WAS NOT A JOKE. I have 22" on my G35 Coupe.
zerothread/266644
Cali 2 Balti G
Dodge Ram Quad Cab
Toyota Sequoia
This thread is about the max wheel size for the G35X not the coupe
So the fact that you have 22s on a coupe has little to do with the max wheel size on the X sedan.
Gimli G35
the X is a little bit taller than a Coupe
If i had a g35X i would go swap my brothers 22"s and see if it fits .. but i dont ... only have a 05 Coupe
5_inch_lip
Car: 2006 G35 Coupe
Cali 2 Balti G wrote:This thread is about the max wheel size for the G35X not the coupe
For comparison reasons...
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
