what size tires do i need
bobbyhill
i just bought new rims and don't know what size tires i need.the rims are 17x8+5 and 17x9+5.i got a stock body s13 with tein ha coilovers.if yall had any ideas or pic please post.
gumby74
I run a 225/45 up front and a 245/40 out back. I am not to aggressive on my drop and do not run crazy camber. Still have about 1.5" fender gap and 1* neg up front though. No rubbing anywhere, and still have my fender liners intact.
Considering the offsets though, I will throw out a 215/45 front and a 235/40 rear. That will be a slight stretch and should allow you to get away with simply rolling the lips.
adrianfromthecastle
Car: 1992 Nissan 240sx
gumby74 wrote:Considering the offsets though, I will throw out a 215/45 front and a 235/40 rear. That will be a slight stretch and should allow you to get away with simply rolling the lips.
225/45's up front and 245's aren't gonna cut it unless you pull your fenders like crazy
bobbyhill
bump
kornaz
Car: 95 240sx SE.
What offset are the wheels?
whiterps13
Car: white LE hatch
215/45/17 front235/40/17 rear
With a +5 offset on both youre still going to need an aggressive roll and some camber. But, they will look great..those are good sizes.
bobbyhill
kornaz wrote:What offset are the wheels?
17x8+5 and 17x9+5
kornaz
Car: 95 240sx SE.
Then what V said:
If you're fine with some stretch, I'd suggest 215's up front and 235 in rear. Sh1t man, i had 215 on a 9" wheel.
